How to Rip and Convert DVD to PVP with DVD to PVP Ripper?
05/27/2020
Watching a DVD movie on your PVP (portable video player) is convenient. If you want to convert DVD to PVP with high quality, fast speed, and flexible customization, you can try out DVDFab DVD Ripper, that is also a DVD to PVP ripper, to convert your DVD to various PVPs like ARCHOS, iRiver, etc. Next is a simple step by step tutorial about how to do the task.
Step 1: Start up DVDFab 9 DVD Ripper, and load in the source DVD
Start up DVDFab 9, choose Ripper option to open the main interface of Ripper. Now load in the source DVD by inserting disc or dragging and dropping DVD backup on your PC into DVDFab program. The longest movie title will be selected by default once the movie is imported in. And you’re free to change audio tracks and subtitles.
Step 2: Choose a profile
Click and open Profile box, navigate to Device, to PVP, then choose a profile according to your display device.
Step 3: Edit audio/video parameters and video effect
Click Advanced Settings button, then go ahead to set all parameters of video and audio.
Click Edit button to bring up Video Effect window, then you can resize source aspect ratio and frame resolution of the video, or crop video for display.
Step 4: Start conversion
Hit Start button on the main interface to start conversion. During the process, all detailed progress info is clearly showed. And you can preview the progress with real time images.
OK, Done. More info about DVDFab DVD Ripper, just go to: www.dvdfab.cn/dvd-ripper.htm
